probably a stupid question but
- burkmanofgod
- 1981 KZ750H2
11 Apr 2009 19:08 #280811
by burkmanofgod
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
probably a stupid question but was created by burkmanofgod
what is the best way to remove the plug over the pilot screw on a Keihin type carburator from a 1981 KZ750H2. The book just says to "use a punch or scriber to deform the plug then remove it." I know parts for this bike are hard to find and costly when found so I don't want to do anything to hurt the carbs. But the plugs do have to come out. So any good tips on removing them?
- PLUMMEN
- Thank you received: 104
11 Apr 2009 19:40 #280827
by PLUMMEN
Replied by PLUMMEN on topic probably a stupid question but
- burkmanofgod
- 1981 KZ750H2
11 Apr 2009 20:06 #280842
by burkmanofgod
Replied by burkmanofgod on topic probably a stupid question but
Soo... Just drill them? What if I drill too deep and hit that brass screw that is so important? How deep should I drill? Or Could I use the back up bits that I have?
- PLUMMEN
11 Apr 2009 20:08 #280844
by PLUMMEN
no just grind the edges and pry them out
- gane
11 Apr 2009 20:14 #280848
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic probably a stupid question but
Burk, actually a good question. Many carbs have been hurt in removing these plugs. plugs come in brass or aluminum. depths vary from 1 to 4mm in depth. jet kits usually come with sharp drill bits and a sheet metal screw for extraction, via prizing.. the risk is drilling thru plug, engaging fuel screw and driving screw into carb body possibly damaging body & or screw. I may over state hazards , but for a 1st timer, I would rec. using l/h drill bit, and drilling at seam of plug, (as opposed to center) stopping frequently and atempting to lever out. the thought of beating on a carb to deform plug leaves me cold. luck g
- timebomb33
11 Apr 2009 21:50 #280877
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic probably a stupid question but
take a 1/8 drill bit drill into it and then use a no. 8 or 10 wood screw and then just pull it out with a set of pliers easy as that just be careful drilling into the plug.
- MFolks
- Thank you received: 540
11 Apr 2009 21:59 #280882
by MFolks
Replied by MFolks on topic probably a stupid question but
Make up a drill stop to prevent drilling too deep. A small dowel with a 1/8" hole in it cut to the length you need should work.
