What carbs match csr650 carbs?
- Muddy
08 Apr 2009 18:16 #279655
by Muddy
What carbs match csr650 carbs? was created by Muddy
The diaphrams in the carbs on my '81 CSR project are shot. Diaphrams are impossible to source so I'm just going to get a new set of carbs. Do any other models/years CV carbs match those on the '81 650 CSR? And does anyone have a set?
Thanks
Thanks
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
09 Apr 2009 04:54 #279844
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic What carbs match csr650 carbs?
Hmmmmm....if you have an 81 CSR 650 you should have slide carbs on it not CV's. The 82 and 83 650's used CV's though. If I'm not mistaken those were BS32's not a real common carb but you could look for a set of BS34's they are much easier to find. One caution, I just noticed this the other day, the 81 650 CSR has a different mounting location for the petcock (further to the rear) than the bikes that used CV carbs so you may run into some clearance issues. Is it possible you have a later model CSR?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- rstnick
- Thank you received: 377
09 Apr 2009 06:12 #279853
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic What carbs match csr650 carbs?
If I'm not mistaken, anarki put VM24SS carbs, which came on most earlier 650s, on his '81 CSR.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- JMKZHI
- Thank you received: 48
09 Apr 2009 07:04 - 09 Apr 2009 07:07 #279864
by JMKZHI
Replied by JMKZHI on topic What carbs match csr650 carbs?
I'm pretty sure he'd loose some hp switching to the VM24s.
And the 81 CSR airbox ducts aren't available, so that would be a problem; I believe the ducts for the earlier 650s are still avialable, so he would need to get an airbox w the smaller middle holes (#2 & #3). The VM24 carbs might be easier to maintain, though. Before getting any CV carbs, I would check into the availability of the diaphragms - those on a used set may need replacing.
Last edit: 09 Apr 2009 07:07 by JMKZHI.
- anarki650
- Thank you received: 5
09 Apr 2009 09:51 #279894
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic What carbs match csr650 carbs?
My 81 CSR had vm24 w/ accelerator pumps. I replaced them with vm24 non-pump carbs from my 77 after I upgraded my 77 to vm26s. Source a set of vm26 carbs and you won't loose any performance from the BS carbs, and you won't have to deal with the diaphrams making your life hell.
09 Kawasaki ER6n
Omaha NE
- Muddy
09 Apr 2009 15:23 #279980
by Muddy
Replied by Muddy on topic What carbs match csr650 carbs?
I took a look at the title again and its an 82 with CV carbs. Will 750 carbs work?
- The Gringo
09 Apr 2009 15:32 #279985
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Yes they will.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Muddy
10 Apr 2009 03:43 #280232
by Muddy
Which 750 model?
- The Gringo
10 Apr 2009 04:50 #280237
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
That depends which brand of carbs you want to run. The 750E and the 750H both came with Keihin CV's while the 750 GPZ's and the L3 came with Mikunis either one will work. I would tend to lean towards the Mikunis due to greater availability of both the carbs and parts for them. Also the Kehins use a pressed in float valve where the Mukunis screw out and are easily replaced. The BS34 Mikunis you need were used on a number of different bikes including the cop bikes so they are not too hard to find. The spacing is the same as for the 650/750.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
