what kawa carb is this? fit on gs750?
- horror1972
06 Apr 2009 10:44 - 06 Apr 2009 10:45
hi,
got this from a local bikeshop.
home.online.nl/m.hordijk/06042009198.jpg
home.online.nl/m.hordijk/06042009199.jpg
They know it's kawasaki, but not if its a 650,900 or 1000.
it measures about 28 mm and has a 102,5 main, a needle with only one groove.
I own a gs750 but it's a pain in the a.. to tune this one since it has a fuel pilot under.
I read somewhere at this forum the kawa carb should be a lot better...
My question, can I put the needle of the suzuki in it, put it on the 4th groove and put a 115 main in, (K&N pods)
I understand I need a dynotest run , but I wanna be close with the settings.
I found 2 plastic washers on the needle, 1mm and about 3 mm, which one should go under the clip, or can i loose the washers?
please help, since I almost go mad by take the carbs apart for the 5th time
Last edit: 06 Apr 2009 10:45 by horror1972.
- KawiConvert
Re: what kawa carb is this? fit on gs750?
06 Apr 2009 12:59
Looks like a Mikuni VM-28. Probably off of a 1000. What do you have on your GS750? Mikuni or Kiehen? Are they CV's?
Check to see if the needles are the right numbers, as the wrong needle won't do any good. My best advise is to put it on and start adjusting the jetting to get it right.
Also, I don't own anything except my little KZ650 so I could be wrong on the carb type. I would suggest searching the VM-26 and VM-28 to see if you can find out which one you have.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- oldkaws4ever
- Have no regrets...... You only live once.
06 Apr 2009 21:31
my guess is mikuni VM-28's with an accelarator pump maby off of and ltd 1000 or z1r? Not sure
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- horror1972
07 Apr 2009 07:48
found it!
its a z1000 1980
thnx
according to wiredgeorge it should fit the gs750.
Thanks for the help
its a z1000 1980
thnx
Thanks for the help
- The Gringo
- ¡Usted no necesita otra motocicleta!
07 Apr 2009 07:55
While it may fit the GS750 since the carb spacing is the same you may run into some tuning issues. The GS Suzukis used a 2.5 slide cutaway where the Kaws used a 1.5. Depending on what you are using for air filters and exhaust it may or may not make a difference.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- keith1
07 Apr 2009 17:01
horror1972 wrote:
iirc,fat plastic goes on top of e-clip and thin one underneath....i think they are there for a reason....what, i m not sure..:laugh: ....good luck.....keith
hi,
