What would be the closest jetting for 28mm carbs
- gkz1000st
03 Apr 2009 22:35 #278258
by gkz1000st
1979 kz1000st dyna s, wiseco 1075, accel coils, k&n filters,4 into 1 header ,shoei fm5 fairing. Mt.pearl Newfoundland
What would be the closest jetting for 28mm carbs was created by gkz1000st
Hi ,my bike is a 79 kz1000st with factory canadian 28mm mikunis (no pump).It has 2 double k&n filters ,aftermarket 4 into 1 but don't know the brand.Dyna 3 OHM coils and dyna s ,wiseco 1075cc with 10.25-1 .The stock (I believe)mains are 107.5 Would like to be able to run it with the baffle if thats an option without too much sacrafice.The bike is not together yet but I am trying to get all I need before I start assembling her.Any advice would really be appreciated.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
04 Apr 2009 03:24 #278272
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic What would be the closest jetting for 28mm carbs
Hello...explore
www.Z1Enterprises.com
as Jeff as setting info on stock 28mm carbs...use this info as a starting point
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- gkz1000st
04 Apr 2009 08:22 #278316
by gkz1000st
Replied by gkz1000st on topic What would be the closest jetting for 28mm carbs
Hi Mcdroid and thanks ,I will check them out.
