Engine Swap which Carbs
- supablake
03 Apr 2009 18:44 #278198
by supablake
Engine Swap which Carbs was created by supablake
So I just finished putting a 81 750 engine into my 78 650sr
I began checking through carbs and the P/O had messed up the CV34's, superglue on the diaphragm and streched/twisted the spring.
I have the old carbs off the 650 which worked fine.
Here's my question.
Do I send the CV's off to WG and have him rebuild them and pay for the new parts -- Or Buy a pair of BS34's
OR - Just put the old Mikunis on and retune them. If so anyone have suggestions on Jetting?
4-1 Kerker, Pods, Dyna etc..
Suggestions?
Blake.
Here's my question.
Suggestions?
Blake.
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
03 Apr 2009 18:47 #278200
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Engine Swap which Carbs
I say put the old mikuni's on to get her running and tune it from there. And save up for a set of BS34's. The rule of thumb is to go up 2 jet sizes for every mod, so 2 for the kerker and 2 for the pods, that should get you in the ballpark were you need to be.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- kano
- Not Another Bloody Limey!
03 Apr 2009 18:56 #278203
by kano
Replied by kano on topic Engine Swap which Carbs
BS34's
- supablake
03 Apr 2009 19:31 #278212
by supablake
Replied by supablake on topic Engine Swap which Carbs
Allready have it Jetted for the 650 with pods and 4-1.
Should be good to go then?
Also I have a Suzuki GS1000 with the BS34's on it. That one's a screamer.
The KZ ran awesome until part of a mystery bolt blew through the block and cam cover. Made it home though. Spewing oil.
I am gonna just stick the Mikunis on and see how the engine runs. The 750 ran about a year ago. I wish I had done a compression test on it back then. I allready bead blasted and painted the block.
Waiting for gaskets and I'll hopefully have it fired up by wed.
Blake
Blake
- oldkaws4ever
03 Apr 2009 22:24 #278257
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Should be good to go, you might have to rejet again cause they will be on a 750, the only true way to know is check your plugs after you run it, they should be a tan color. Let us know how you make out.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- supablake
04 Apr 2009 19:46 #278454
by supablake
Well I got it together today. Re-used exhaust gaskets and valve cover gasket. Wanted to know if it ran at all.
IT DOES!! Started right up! Minimal tweeking and it really goes! That Kerker pipe is loud, setting off car alarms left and right.
Im still going to check the Jetting, it might be running a bit lean. Popping on decel, but that might be the exhaust gaskets.
We'll see when the parts come in.
Blake
Blake
- oldkaws4ever
04 Apr 2009 23:22 #278531
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Awsome......good to hear
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
