- Thank you received: 1
Air Screw O-Ring Question
- HerrDeacon
03 Apr 2009 17:48 - 03 Apr 2009 17:56 #278183
by HerrDeacon
Air Screw O-Ring Question was created by HerrDeacon
What affect could a bad (i.e. hard and badly cracked) air screw o-ring on a VM24SS have on the running of a bike? Could it affect cold starts, idling, etc.?
The reason I ask is that I was just cleaning my carbs and noticed that one of these o-rings was in bad shape. It just so happened to be the same cylinder that was giving me issues last year before putting the bike away. That cylinder wouldn't run when on the choke.
Also, where can you pick up o-rings? Are these specific to this carb, or can these be found at hardware stores or Canadian Tire? What size are these?
Thanks
Thanks
Last edit: 03 Apr 2009 17:56 by HerrDeacon.
- 78z1Joe
- My man cave is my garage....
- Thank you received: 21
03 Apr 2009 18:56 #278204
by 78z1Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Replied by 78z1Joe on topic Air Screw O-Ring Question
Hi, if the o-ring is dried out or stiff, I would replace it. t's either there to keep the air out or the gas in. I replaced mine and got them at z1enterprises.com they have a wealth of parts for vintage bikes. You could also try your local dealer as well. They might even have them in stock. Good luck, Joe
1978 KZ 1000
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- Thank you received: 2829
03 Apr 2009 19:33 #278213
by 650ed
Replied by 650ed on topic Air Screw O-Ring Question
In the parts manual for the '77 KZ650C1 it shows the o-ring as part #16038-022 (this is on the carbs with the air screw on top). Good news - still available from Kawasaki; bad news - more than $2.50 each! I would think if you took one to a large hardware store or plumbing supply house they could find something the right size for less $$. Ed
- MFolks
- Thank you received: 540
03 Apr 2009 20:30 #278238
by MFolks
Replied by MFolks on topic Air Screw O-Ring Question
Hardware store O rings may not stand up to gasoline, I think they are Buna-N. Ask at Z1 enterprises, Jeff Saunders recently tested several types of O rings by putting them in gas and see if they swelled or broke down.
- HerrDeacon
04 Apr 2009 03:22 #278271
by HerrDeacon
Replied by HerrDeacon on topic Air Screw O-Ring Question
Thanks guys. I think I'll try the hardware store to get me going. I have to order a few things from Z1 in a month or so, I'll inquire then.
So, could this oring problem negatively affected the running to this extent though. Can't believe I never noticed them last year when having this problem.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
04 Apr 2009 03:28 #278273
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Air Screw O-Ring Question
I just ordered enough miniature o-rings from
www.z1enterprises.com
to do all my carbs...costly but worth it. Be aware that these are special order items through Jeff and take several weeks to deliver.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
- Thank you received: 48
04 Apr 2009 08:07 #278307
by JMKZHI
Replied by JMKZHI on topic Air Screw O-Ring Question
HarborFreight & other places sell nitrile o-ring kits for $10-$20. The o-ring size for the air screws is probably an 005 or 004, so if you find a kit make sure it has the needed size. Of course, to get an idea of what size to get, measure your o-rings, including the cross-sectional dimension. I got a kit from HF a few years ago - the smallest o-ring is an 006.
- JMKZHI
04 Apr 2009 08:17 #278312
by JMKZHI
- Mcdroid
- Gone Kwackers
04 Apr 2009 08:31 #278320
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
JMKZHI wrote:
Or, I could measure the two sizes of itty bitty o-rings that are used in the VM26 carbs...if anyone is interested?
Or... Viton o-ring 004 ... Viton o-ring 005
I have no idea if these sizes will work.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
