need some help
- judgie
02 Apr 2009 15:05 #277752
by judgie
forever tweeking aircooled engines, well it is my job
77 z650c1
need some help was created by judgie
have pu;lled the motor out and torn it down a sit needs a rebild.
77 z650.
when i removed the inlet rubbers i was shocked to see the inner dia is smaller than the ports on the head.
the carb sits into these and then were they bolt to the head the dia is samller than the ports in the head.
to me this is planely wrong but is it the norm on these bikes?
bike has never revved out proberly and im guessing this is one of the reasons why.
can i fit bigger carbs and manifolds and from which bike can i get them?
cheers rob
77 z650.
cheers rob
77 z650c1
- judgie
09 Apr 2009 00:57 #279824
by judgie
77 z650c1
Replied by judgie on topic need some help
any one have any ideas or help on this?
looks like i have got myself some high lift cams, just waiting for them to turn up.
what bigger carbs are going to fit my engine?
77 z650c1
- rstnick
- Thank you received: 377
09 Apr 2009 06:22 #279854
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic need some help
Mikuni VM26, VM28 and VM29 smoothbores can fit, as well as other type of BS carbs and probably more.
The manifolds will need to be changed as you mentioned.
Have a search in the carb section and elsewhere as there have been discussions on this in the past.
I'm not really good with carb info.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
