- Thank you received: 1
Bench checking of Float Levels
- HerrDeacon
02 Apr 2009 08:42 #277678
by HerrDeacon
Bench checking of Float Levels was created by HerrDeacon
I've only checked and adjusted my float levels (clear tube method) with the carbs on the bike. It's a bit of a pain though getting the bowls off and such. Anyone have any tips for setting up the carbs so they can be done off the bike? How do you support them and keep them upright and level? Getting fuel to them? Any pics of your setup?
Thanks
Thanks
- JR
- Thank you received: 449
02 Apr 2009 09:33 #277687
by JR
Replied by JR on topic Bench checking of Float Levels
Taking the carbs on and off the bike is a PITA. The last time I adjusted the floats I used a Black & Decker workmate to hold the carbs and I used a little fuel tank from a lawnmower with a clamp on the fuel line to the carbs.
It took about 3 or 4 on/off/adjust cycles before I had all the levels in the clear tubes just where I wanted.
Hope I dont have to do this for some time to come. I'm sure there is an easier method than mine.
- OnkelB
- Thank you received: 80
02 Apr 2009 09:48 - 02 Apr 2009 09:49 #277689
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Bench checking of Float Levels
Nate (NONB) came up with this great idea of using a pair of spare intake manifolds and some plywood to make a carb jig, I just added a plate to hold a drip pan.
Setting the jig up in a vice you can get the carbs level on one axis, using a C-clamp you can get them level on the other axis - works like a charm, got the float levels set spot on in about an hour.
Last edit: 02 Apr 2009 09:49 by OnkelB.
- OnkelB
02 Apr 2009 09:49 #277690
by OnkelB
- OnkelB
02 Apr 2009 09:50 #277691
by OnkelB
- Mcdroid
- Online
- Gone Kwackers
- Thank you received: 318
02 Apr 2009 09:56 #277695
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Bench checking of Float Levels
Yeah I remember that thread and was planning on making one of those this weekend...I start 12 days off starting Saturday...no place to be but my garage:woohoo: :woohoo: :woohoo:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mtkawboy
- Thank you received: 16
02 Apr 2009 10:04 #277697
by mtkawboy
Replied by mtkawboy on topic Bench checking of Float Levels
Thats a better idea then mine but I have a vise that attaches to my bike lift. I roll it outside so I dont spill gas in the garage and clamp them in the vise in a towel & level them. I think Ill build the board setup
- HerrDeacon
02 Apr 2009 10:25 #277701
by HerrDeacon
Replied by HerrDeacon on topic Bench checking of Float Levels
That's excellent guys, thanks for posting those. Great setups. I'm going to have to try and rig up something like that.
- mark1122
- Keep twisting it
- Thank you received: 109
02 Apr 2009 12:21 #277715
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Bench checking of Float Levels
I use the workmate as well. i dont have to take the cables off that way. just put the bench beside the bike. works for me.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Russ Jackson
02 Apr 2009 15:31 #277757
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Bench checking of Float Levels
This float level question comes up all the time. Someone should post a short video...Russ
- JMKZHI
- Thank you received: 48
02 Apr 2009 15:41 #277760
by JMKZHI
Replied by JMKZHI on topic Bench checking of Float Levels
- JMKZHI
02 Apr 2009 15:42 #277762
by JMKZHI
