- Thank you received: 4
Fine Tuning Kz650
- KawiConvert
As for mechanical, I've checked compression and I have 140-150 dry in all cylinders with choke off and throttle wide open. My valves are all within spec and my timing is functioning correctly. I still have the points and condensers, but I have set them, gaped them and the advancer moves fine. I have not synced my carbs other than the bench top sync I did using a drill rod.
When warm my bike will generally hold a 900-1200 idle, though it has died a time or two while idling.
Any thoughts are appreciated on what I can change to get the power throughout the RPM's to be more consistent.
Thanks,
KC
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- GalwayZ
- GalwayZ
good luck
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- Thank you received: 2829
- KawiConvert
She runs with no backfiring, popping, or other odd noises. If I go WOT just after take off the engine starts to choke out and almost die, not sure if that is common for non-accelerator pump carbs.
As for intake, I don't have access to a stock airbox so I cannot switch back even if I wanted to. I have considered going to either the VM26 or BS324 carbs, but I do not know if this would help or if there is something I can do to my VM24's to make the motor run a little hotter. Also, including the carb switch I've looked at K&N pods to replace my emgo style filters.
Eventually I want to switch out for a 750, but if that never happens then I want to get as much power out of the stock engine as I can. Right now I only get about 35 mpg and stock Chevy pickups have more top end and almost as much acceleration.
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- KawiConvert
What do your plugs look like?
When I did the compression test, two were light tan, two were a dark brown. This was after riding 12 miles home and idling for about a minute.
- N0NB
If you think you'd need an airbox, I think I have an extra but probably don't have the filter cap as I sent one to OKC_Kent a couple of years ago.
Nate
- KawiConvert
The darker ones may be a bit rich. Sonds like you may have to lay in a supply of plugs and do a bunch of throttle chops to figure out your jetting.
I appreciate the offer, but I think it is very close right now. Mainly I am looking for a way to enrich the mixture from off idle to 4500 RPM's and from 7500 up. I am looking at KN filters, but I don't want to go that route till I decide on carbs and an engine swap. For now I think it needs to be enriched because I have some improvement in that range if I pull the choke lever up about 1/3 of the way, even when the bike is warm.
- bountyhunter
- Thank you received: 337
I am looking for ideas and help with getting my carbs set just right. As they are now, I've got a decent bottom end, flat from about 2500 to 4500, alive from 4500 to 7500, and gutless from 7500 on. I may be going to a 4-1 exhaust until I can modify the stock ones to where I want, but for now I am trying to figure out why the power is coming in only at one place.
Thanks,
KC
I notice in your tag line it says:
"with pods "
The symptoms are:
"As they are now, I've got a decent bottom end, flat from about 2500 to 4500, alive from 4500 to 7500, and gutless from 7500 on."
This part sounds like the main jets are off:
"gutless from 7500 on."
This part:
"flat from about 2500 to 4500, alive from 4500 to 7500,"
Sounds like the needle taper is wrong or the needles are in the wrong place.
With pods, you can make engine tuning your life's work. The jet sizes and needle taper sre dialed in by the maker to match the flow characteristics across the RPM band. Changing to pods changes the flow characteristics.
- bountyhunter
NO, it's not. Mine has no ac pump and it hits hike a freight train if I slam the throttle open.She runs with no backfiring, popping, or other odd noises. If I go WOT just after take off the engine starts to choke out and almost die, not sure if that is common for non-accelerator pump carbs.
Here is one thing nobody thinks about and I learned the hard way:
Check the rubber diaphragms on the vacuum pistons for tiny slits around the edges. If they leak just a little, they run lean at light throttle hit but run sort of OK at larger throttle. I screwed with jets a long time before I found out the rubbers were leaking just a little.
Also: check the fuel levels in the bowls with clear tube. Poor throttle hit is a classic symptom of low fuel level.
The other way to improve throttle response is to raise the needles.
