Z1R carbs ready to start
- Z1Rider
- rstnick
- Thank you received: 377
There are two others on page 2 in the carb section for Z1Rs.
Might just need to find new O-rings for the T.
Do post up some pix of the finished bike. Love the Z1R.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Thank you received: 797
www.sudco.com/Diagrams323728/expvm29.gif
they say to call.
hth,lemme know if you call and what they tell you if you don't mind.
leon holmes
i took a razor and carefully cut the o-ring lookin section off and got some o-rings and shoved on and put them back together about 11 years ago and it has worked.i would like to replace it with the correct one.i have also thought about spinning up an aluminum t that accepts o-rings.
when i have to i guess i will go that route if i cant find the rubber covered one.
leon holmes
- Thank you received: 2098
Click here > fuel pipe joint
Another option is tighten the fitment by wrapping with teflon tape. The white tape is okay, but seem to recall the yellow tape is designed for use with fuel.
Good Luck!
dang know i better go look for those float bowl gaskets and i "might"be able to dry my carbs up completely.won't know what to think about not having to wipe fuel residue off my starter cover anymore,hehe.
thanks again patton,
leon holmes
...thanks for postin the link...float bowl gaskets and i "might"be able to dry my carbs up completely....
You're more than welcome.
Maybe just lucky, but have used the same float bowl gaskets over and over for many years with no leaks.
Where fuel escapes past the floatbowl gasket, sometimes using two float bowl gaskets (instead of just one) will help better seal the bowls against the carb body.
I believe it was Jeff Saunders of Z1E who also suggested checking the ears on the floatbowl where the screws go through to see whether the ears might have become slightly bent enough (toward the carb body) to disallow a snug fit. If so, it should be possible to carefully straighten the ears and regain a tighter fit.
Good Luck!
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
....won't know what to think about not having to wipe fuel residue off my starter cover anymore,hehe.
leon holmes
You too, eh? :laugh:
Build Thread
leon holmes
