leaking carb!
- Davestradamus
01 Apr 2009 19:34 #277538
by Davestradamus
leaking carb! was created by Davestradamus
i have a 78 kz650 with mikuni carbs. the carbs are leaking fuel between the housings and the plate where the boots are attached.
i cant get the bike to fire! i am not sure if fuel is making it into the cylinders. where should i start?
thanks
david
thanks
david
- rstnick
- Thank you received: 377
02 Apr 2009 06:54 #277655
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic leaking carb!
Try a search in the carb section here and at kz650info (link in my signature) for similar problems.
You gotta fix the leak first. Abetter description of where it's leaking would help.
The spark plugs will look wet if gas is making it into the cylinders.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Davestradamus
06 Apr 2009 11:25 #278879
by Davestradamus
Replied by Davestradamus on topic leaking carb!
i have determined that the petcock is leaking slightly. it must be filling the carbs with gas. and i think the floats are stuck. should i be able to move them freely from the exterior of the carbs? i hope all this gas sitting in them doesnt gum them up too bad.
thanks
david
thanks
david
- Thank you received: 2098
07 Apr 2009 16:53 #279256
by Patton
Replied by Patton on topic leaking carb!
Would sniff-test crankcase oil and examine its condition to determine whether fuel has entered the crankcase and contaminated the oil.
Good Luck!
Good Luck!
- timebomb33
- Thank you received: 10
07 Apr 2009 17:03 #279258
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic leaking carb!
sounds like you will need new needles and seats for sure.they are available from sudco and are actually very reasonable to buy. get those and a petcok rebuild kit or go with a new pingel petcock and your problems should be solved.
