Lean?
- Mikesz28lt1
30 Mar 2009 18:34 #276883
by Mikesz28lt1
Lean? was created by Mikesz28lt1
Just installed a vance and hines exhaust, emgo pods, and the dynojet stage 3 kit. I installed the 165 main jets. The bike runs great from idle to 7500 with the baffle installed, and to 6500 without it. After that it has a bad miss. Does this sound like it is running lean? The pipes have allready started changing colors after 50 miles. If it is lean does anyone have a suggestion on what to bump the jets up to? Thanks in advance.
- Mikesz28lt1
30 Mar 2009 18:35 #276884
by Mikesz28lt1
Replied by Mikesz28lt1 on topic Lean?
Oh yeah, by the way the bike is an '82 1000 LTD, stock except what is listed.
- anarki650
- Thank you received: 5
30 Mar 2009 19:22 #276904
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Lean?
The spark plugs will tell you if it's lean. Do a plug chop at high rpms and if the plugs are white you're lean.
09 Kawasaki ER6n
Omaha NE
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
30 Mar 2009 19:29 #276906
by kzz1p
Replied by kzz1p on topic Lean?
165 main jets are way to big. No stock Z with a pipe, uses jets that big. Try something around 117.5 and see what happens.................
