either/coldstart,warm easy start
- goatee
29 Mar 2009 16:15 #276502
by goatee
either/coldstart,warm easy start was created by goatee
z1 big bore k12 dyna s 28mm mikuni.When it is cold it takes a few kicks and some either to start ,once warm pops right off.Whats wrong?Thanks in advance.p.s. when timing ignition w/a timing light at idle I cant get the pointer to line up over the f mark on the advance.Help
- Thank you received: 2829
29 Mar 2009 18:09 #276539
by 650ed
Replied by 650ed on topic either/coldstart,warm easy start
Are you sure your "starter plunger" (choke) system is working properly and everything related to it is clean? Ed
