Gasoline/Petrol formulation
- Jeff.Saunders
28 Mar 2009 11:55 #276095
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Gasoline/Petrol formulation was created by Jeff.Saunders
It seems within the past year or two, the gasoline suppliers are introducing some different mixes to the pumps.
A couple of years ago I tested some carb o-rings I had bought in bulk by dropping them in gasoline - they didn't swell or change in any way. I still have a supply of those o-rings. I dropped some in some fresh gasoline and the o-rings swelled up to twice their size... ...hmmm.... what is going on?
I don't have any equipment to test fuel, but I'm wondering if alcohol in the mix or other chemicals are causing this.
Anyone in the industry have any insight?
Z1 Ent on Facebook,
- bountyhunter
- Thank you received: 337
28 Mar 2009 12:24 - 28 Mar 2009 12:26 #276101
by bountyhunter
Replied by bountyhunter on topic Gasoline/Petrol formulation
Out here in Kali we have been forced to use gas with 10% ethanol for many years now. It also had MTBE for many years which has now poisoned most of the ground water..... The only thing we know for a fact is that the "oxygenated" gas with the "clean air" additives gives less power and worse fuel mileage.
The diesel truckers have long complained the fuel out here was destroying the seals in their fuel pumps.
Last edit: 28 Mar 2009 12:26 by bountyhunter.
- loudhvx
- Thank you received: 1616
29 Mar 2009 15:31 #276487
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Gasoline/Petrol formulation
Jeff, just curious, were the orings Viton or Nitrile (Buna N)?
13 or 14 years ago I bought an old Dodge that sat for several years. The rubber fuel lines all seemed fine (and I checked) when I bought the car, but after about 2 or 3 fillups, the car just gushed gas out onto the street every where. The fuel lines all turned into a putty or clay-like substance. If you squeezed it, you could mold it like playdough... very disturbing.
1981 KZ550 D1 gpz.
Other links.
- Jeff.Saunders
29 Mar 2009 16:49 #276518
by Jeff.Saunders
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Gasoline/Petrol formulation
I'm not sure what they are. That was the reason I dropped them in gas in the first place. I'd bought them at the local Grainer - and wasn't too sure if they'd hold up to being on a carb drain plug - they did - at least until recently.
Z1 Ent on Facebook,
- H2RICK
- Is this a fun bike, or what!!!
29 Mar 2009 20:33 #276620
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Gasoline/Petrol formulation
They are probably buna-N which does NOT like alcohol of any type. You may want to check into this whole thing but I believe you'll be okay with viton rings. Check with your local Parker-Hanifin distributor or download their online catalogue. It is absolutely full of material compatibility info.
- eddiem
- KZR FLAG RELAY CARRIER #63
- Thank you received: 34
29 Mar 2009 21:50 - 29 Mar 2009 21:55 #276634
by eddiem
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Replied by eddiem on topic Gasoline/Petrol formulation
if I remember right viton should be brown
I was wrong they come black or brown
208.72.236.210/html/pg-758252.html
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Last edit: 29 Mar 2009 21:55 by eddiem.
- timebomb33
- Thank you received: 10
29 Mar 2009 22:11 #276636
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Gasoline/Petrol formulation
ever since the government mandated that there was to be no more leaded fuels we have been experiancing carb and petcock problems it has gotton really bad in about the last 5-6 years. i have seen myself filling up a bike and less then 5 mins. later watching the petcock o-rings and seals disintagrate before my eyes. carb rebuilds only last half as long as they used to needles and seats are lasting as long as they should. the additive packages that are being added to the fuel to keep the octane levels up are destroying the rubber and brass parts in the carbs escpecally in older bikes this could be the thing that keeps us from riding these bikes as much as we should. some body is going to have to come out with proper replacement kits for these carbs that will stand up to the fuels we have now.i keep hearing about viton as a good replacement but i haven't seen any kits made from this.if you guys have been paying attn. to the post on here 3/4 of them latly have been carb related it is not coincedence.
- PLUMMEN
- Thank you received: 104
29 Mar 2009 22:36 #276661
by PLUMMEN
Replied by PLUMMEN on topic Gasoline/Petrol formulation
alcohal carbs?
- loudhvx
30 Mar 2009 00:57 - 30 Mar 2009 01:00 #276672
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Viton is a tradename used by Dupont. There is also something called Viton ETP which handles brake fluid in addition to gasoline fuels. Regular Viton is not recommended for brake fluid.
There was some attempt in the industry to color code o-rings, but it never really panned out. As a result many different o-ring materials can look the same, and two o-rings of the same material can look different.
1981 KZ550 D1 gpz.
Other links.
Last edit: 30 Mar 2009 01:00 by loudhvx.
