78 z650 - mikuni carbs - parts.
- GalwayZ
27 Mar 2009 08:33 #275793
by GalwayZ
78 z650 - mikuni carbs - parts. was created by GalwayZ
Anybody know where i can get carb bodies - at some point someone broke one float post on each outboard carb - they did repair them - turned up some little posts and drilled the base of the original and threaded the new posts in - effective but the alignment is not perfect 0 the floats are a little skewed) - if i could get the two outboard bodies it would be a better solution -
Cheers
Cheers
- MFolks
- Thank you received: 540
27 Mar 2009 12:13 #275858
by MFolks
Replied by MFolks on topic 78 z650 - mikuni carbs - parts.
Some carb parts websites:
1. www.nrp-carbs.com
2. www.motorcyclecarbs.com
3. www.carbparts.com
4. www.carbkitscapital.com
- Bluemeanie
- Thank you received: 14
27 Mar 2009 13:12 - 27 Mar 2009 13:13 #275862
by Bluemeanie
Replied by Bluemeanie on topic 78 z650 - mikuni carbs - parts.
Ebay is a good source for carbs, always good to have a spare set or two for bowls, jets, etc. Here is a couple for cheap...
KZ650 carbs
KZ650 carbs
KZ650 carbs
KZ650 carbs
Last edit: 27 Mar 2009 13:13 by Bluemeanie.
- kawsakiman
- Thank you received: 6
27 Mar 2009 16:19 #275884
by kawsakiman
Replied by kawsakiman on topic 78 z650 - mikuni carbs - parts.
i have a set of 24's already apart for cheap.
they were dirty as hell and carbs to experamint with.
they are the non accelerator pump style.
a donatation to this sight and shipping and you can call them yours.
