smoothbores
- tanner
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
i put 29mm smoothbores on my bike and i want to put a chorome petcot on what kind do in need?the carbs have the fuel line and to vacume lines
All you need is a single feed gas line for 29's.
- tanner
- Thank you received: 2098
what about the vacum lines
Those aren't vacuum lines.
Perhaps referring to the two float bowl vent lines that are supposed to exit to open air.
Mine are routed to underneath the seat.
Good Luck!
- Russ Jackson
- Thank you received: 1
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
there's another vacuum line
coming from between the two
right hand carbs.
- irishwill
- Thank you received: 6
like patton says they are vent lines not vaccuam lines, no such thing on 29 smoothies as vacuam lines.buy a pingle single feed street petcock and you will get good looks as well as excellent flow
Pingel is the only way to go!!!
- saxjonz
- KawboyZ
- Thank you received: 76
But its your two cents that have to be spent in order to realize that.
79 LTD B3
