re jetting the carb when you remove the airbox..?
- Tater37
24 Mar 2009 18:33 #275050
by Tater37
re jetting the carb when you remove the airbox..? was created by Tater37
Im new here so Thank you to all who might be able to help.
I have a 1979 KZ1000. just got it. Benn sitting for a few years and the carbs are froze up, Going to rebiuld them as well as other stuff. But I want to aliminate the airbox and install the K n N filters instead. But Im just assuming I will have to go up in jets to compensate for more air correct? The carbs are stock on there now.
Thanks in advance.
Tater37
Thanks in advance.
Tater37
- bountyhunter
- Thank you received: 337
24 Mar 2009 22:31 #275129
by bountyhunter
Replied by bountyhunter on topic re jetting the carb when you remove the airbox..?
I believe rejetting will be mandatory. I also believe they will never run right.
- Pro_window78
26 Mar 2009 18:40 #275656
by Pro_window78
Replied by Pro_window78 on topic re jetting the carb when you remove the airbox..?
Get wiredgeorge to do your carbs and tell him your pipe/filter combo and it will run great just like my bike!!
