- Thank you received: 2
jetting question for 28 mm
- keith1
23 Mar 2009 18:00 #274666
by keith1
jetting question for 28 mm was created by keith1
i bought a set of 28's off ebay...decent but need a going thru....a set to learn on and use for a bit.....would i jet these like a 26..? #20 pilot mains and 115 mains for my set-up....i bought 3 sets of mains...115, one up and one down.....i m not sure how much of a difference the 2 mm's are going to make at idle and rolling thru as far as jetting...i have 2 sets bowl gaskets and i set tops and some k and l kits ive had hanging around..this stuff is for a 26, but i m guessing they fit 28 of the same period....if they fit, i will be replacing jets, float valves and the pc they reside in,associated o-rings, e-clips, etc....2 cans of carb clean and firing up the compressor...been highlighting the manual and i think i m ready to go....fri/sat should be interesting.....thanks in advance for any tips and suggestions.....keith
- timebomb33
- Thank you received: 10
23 Mar 2009 20:05 #274711
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic jetting question for 28 mm
yes i would start out there and you should be close it will depend on your elevation and type of riding you do but that jetting should get you close.
- keith1
24 Mar 2009 14:29 #274949
by keith1
Replied by keith1 on topic jetting question for 28 mm
thanks....i will start there.....dying to ride and just might get a quick spin in sat.....:woohoo:
