Stupid fuel petcock question...
- BradP77
22 Mar 2009 18:54 #274374
by BradP77
Stupid fuel petcock question... was created by BradP77
The manual fuel petcock on my 77 KZ1000-B1 has 2 fuel outlets (one goes down and one goes back), as the original VM26 carbs had two fuel inlets. I am putting 29 smoothbores on my bike, and they have only one fuel inlet. Which fuel outlet do I use, and do I cap the other one off? Or do I need to use a T and use both outlets?
- PLUMMEN
- Thank you received: 104
22 Mar 2009 21:03 #274419
by PLUMMEN
Replied by PLUMMEN on topic Stupid fuel petcock question...
should work either way depending on your riding habits,just remember those ltd tanks dont hold much fuel!
- Thank you received: 2098
22 Mar 2009 21:34 - 22 Mar 2009 21:55 #274425
by Patton
Replied by Patton on topic Stupid fuel petcock question...
BradP77 wrote:
As plummen says, should work either way. Both petcock nipples function the same. Use either nipple and cap off the other nipple. A standard vacuum nipple cap works just fine.
The pic below is from a petcock with both nipples toward the inside. On the LTD style petcock with one nipple pointing down, would select either nipple that best routes the fuel line.
Good Luck!
[Click on image to enlarge view]
Good Luck!
Last edit: 22 Mar 2009 21:55 by Patton.
- timebomb33
22 Mar 2009 23:39 #274454
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Stupid fuel petcock question...
you might get better flow to the bowls if you use a tee and feed both sides of the carbs at the same time
- Russ Jackson
23 Mar 2009 03:11 #274465
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Stupid fuel petcock question...
I just went through this on my bike. First thing I would do is remove the stock petcock and replace it with a pingle. I just couldn't get enough gas to my 29s. The difference was unreal...Russ
