- Thank you received: 2
are these 28s?....single feed, i cant tell..
- keith1
these might be a deal if they are what they say they are.....
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...IT&item=270362177957
any ideas???.....thanks...keith
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If I'm correct. :side:
Maybe some of the other "more knowledgables" here can tell you more.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
Looks as though they are. Pretty sure I can see the fuel feed T right in the middle there and it branches through the four of em'...
if I'm correct.
Cheers.
thanks, i just cant find anything anywhere quick that says they made 28 s with a single feed....
- keith1
if I'm correct.
Cheers.
i own them......hopefully more ifo will be posted....thanks tek...........
- Thank you received: 2098
if I'm correct.
Cheers.
For example (probably one of many)is the 1979 KZ1000-A3 28mm carb assembly with a single fuel line inlet.
(See pic in next post from kawasaki.com)
Good Luck!
[Click on image to enlarge view]
- keith1
