Testing bike with vaccuum line on petcock
- sean5775
21 Mar 2009 15:37 #273971
by sean5775
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
Testing bike with vaccuum line on petcock was created by sean5775
I have this KZ440 a 1981, its the first bike I have ever owned or had to work on with a vacuum line going to the petcock. I want to run it off my auxiliary fuel tank that I use for testing. I was wondering if I need to hook up the vacuum line from the carburetor to anything so it will run properly or can I just leave it or plug it?
- MFolks
- Thank you received: 540
21 Mar 2009 17:01 #273987
by MFolks
Replied by MFolks on topic Testing bike with vaccuum line on petcock
If your petcock has a pri or prime setting, you will not have to hook up a vacuum line to get fuel to flow.
- gane
- Thank you received: 1
21 Mar 2009 17:41 - 21 Mar 2009 17:43 #273997
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Testing bike with vaccuum line on petcock
You should however block the vac. line to carb. or there will be a vac. leak to that carb, G
Last edit: 21 Mar 2009 17:43 by gane.
- coppertales
24 Mar 2009 11:59 #274904
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Testing bike with vaccuum line on petcock
A golf tee works great for plugging that vaccuum line.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
