carbs
- djs699
Re: carbs
04 Mar 2006 10:49
The outside looks the same as the "rs" series. Inside they are different. The slide is flat, bout 5/16" thick, rides in a molded plastic peice that acts as guide and locator. That peice has two screws holding it inside the carb. Other parts look the same later KZz factory carbs. Bowls have rubber ring, like an "o" ring for a seal instead of flat gaskets. Think I'm gonna order a few of those parts and see if they work. If I get you numbers can you supply parts George?
Thank
Thank
- djs699
Re: carbs
04 Mar 2006 10:52
Also, only numbers I've found are inside the bowl, 35026. Outside markings are "Mikuni Corp" and "Made in Japan".
Thanks
Thanks
- wiredgeorge
Re: carbs
05 Mar 2006 12:27
My business isn't set up to supply parts at this time. I suggest you contact Sudco. I truly don't know what the heck those carburetors are but are probably from a newer bike with the same carb spacing as KZ which would make it either a Suzuki or Kawasaki or someone modified a rack from another brand which isn't all that hard to do.
