- Thank you received: 12
smoothbore float level
- lewisj
19 Mar 2009 08:42 - 19 Mar 2009 11:54 #273373
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
smoothbore float level was created by lewisj
I am rebiulding a set of 29mm smoothbores for my 73 z1.. Only mods are K&N pods and a Vance and Hines header. Just purchased new floats from z1 enterprises and need to know how to adjust to the correct level. Carbs are off the bike and on the bench. Also, what position would you have the needle on? Any help would be great.
Thanks Jim
Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Last edit: 19 Mar 2009 11:54 by lewisj.
- mark1122
- Keep twisting it
- Thank you received: 109
19 Mar 2009 12:59 - 19 Mar 2009 13:00 #273433
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic smoothbore float level
the level should be 23mm.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 19 Mar 2009 13:00 by mark1122.
- lewisj
19 Mar 2009 17:21 - 19 Mar 2009 19:11 #273545
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Replied by lewisj on topic smoothbore float level
Thanks Mark! Is that measurement from the gasket to the bottom of the float, when the carbs are upside down?
Thanks Jim
Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Last edit: 19 Mar 2009 19:11 by lewisj.
- Thank you received: 2098
19 Mar 2009 19:09 - 19 Mar 2009 19:10 #273571
by Patton
Replied by Patton on topic smoothbore float level
Middle clip on jet needle.
Fuel level 2-4 mm below carb body (below the red line in pic).
Best to use clear tube method for measuring service fuel level (with carbs on or off the bike). The upside-down-on-the-bench measuring method often produces inaccurate levels.
Good Luck!
Good Luck!
Last edit: 19 Mar 2009 19:10 by Patton.
- lewisj
19 Mar 2009 19:15 #273573
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Patton, that helps alot!! I will set it on the bench first then use the clear tube method once its on the bike.
Thanks again guys!
Jim
Thanks again guys!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- mark1122
- Keep twisting it
19 Mar 2009 19:40 #273582
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Now youve got it. u get them close on the bench. 23mm from the gasket surface to the top of the float.the floats are not all exactly the same weight, so then u fine tune them with gas and the tube trick.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
19 Mar 2009 19:43 #273585
by kzz1p
Replied by kzz1p on topic smoothbore float level
As for the needle position. I would start with it in the middle. If that is to lean, move the needle down one notch to richen it up..........
