carb leaking 78 kz650b2 1st bike HELP
- Hobo13
18 Mar 2009 14:55 #273161
by Hobo13
carb leaking 78 kz650b2 1st bike HELP was created by Hobo13
i own two 78 kz650b2's one runs one does not. these r my first rides. i am 38.ineed all the help i can get. one bike runs good. bought it w a parts bike.rode it around some ,get the feel,broke cluth cable,stalled bike.pushed it home.replace cable. start bike. fuel begins rushing fromthe bottom of the left carb.it appear to be from a overflowof some sort[its leaking out a rubber line] if i pinch the line shut,the leak moves to out of the air filter[same carb] i put a screw in the line,the leak moved to the other three carb bottoms.all the while,the bike idles&revs. please help
- Thank you received: 2829
18 Mar 2009 15:00 #273162
by 650ed
Replied by 650ed on topic carb leaking 78 kz650b2 1st bike HELP
See my response to your same question under the thread "750 carbs to my 650 "
- timebomb33
- Thank you received: 10
18 Mar 2009 19:12 #273218
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic carb leaking 78 kz650b2 1st bike HELP
replace the float valve assembly it is messed up replace all 4 as it is just a matter of time before the other three do the same and change your oil as well because the fuel will fill up the bottom end if left unrepaired.
