- Thank you received: 10
81 KZ750 Carbs
- timebomb33
17 Mar 2009 21:40 #272954
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 81 KZ750 Carbs
going level will get you in the ball park just make sure they are even
- burkmanofgod
- 1981 KZ750H2
17 Mar 2009 22:20 #272967
by burkmanofgod
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
Replied by burkmanofgod on topic 81 KZ750 Carbs
Ok I feel like an idiot. I am ready to put the bowls back on but the gaskets which fit right when they were new a few days ago seem to have swelled or streatched or something. The gaskets do not want to set into the grove around the bowl anymore. Do they just need to dry out? (Even though they feel dry to the touch) or is there some trick to this that I just don't know? I can't believe that the gaskets are only good for the one install and then they need to be replaced already.
- Thank you received: 2098
18 Mar 2009 14:30 #273152
by Patton
Replied by Patton on topic 81 KZ750 Carbs
If needed, Z1E carries the rubber rings.
Here's the link to click > O-rings for float bowl
Good Luck!
Good Luck!
- JR
- Thank you received: 449
18 Mar 2009 19:15 #273219
by JR
Replied by JR on topic 81 KZ750 Carbs
Hi There burkmanofgod
I have the same carbs - Keihin CV34 - and a bit of experience with them so hope I can help
To go back to your first question - the bowl seats dont some out. They are pressed in. Dont even try to remove then or you'll bugger then up permanently.
If you have new float needles and that did'nt work then dip a Q tip in carb cleaner and run it around and around in the carb seat. If that does not work then try Brasso or something similar
Also do what the guys above said regarding float height.
Finally, those float bowl gasket/large O rings are made of crap, new ones included. Once removed from a float bowl they lose their shape, expand and dont want to go back in. What workd for me is to pack each one individually in a small freezer bag and put them in the freezer for 20 minutes. That shrinks them down. Take them out of the freezer one at a time and install before they expand again.
Hope it helps. Good luck
- burkmanofgod
- 1981 KZ750H2
20 Mar 2009 06:50 - 20 Mar 2009 06:51 #273670
by burkmanofgod
Thanks for the tips. I was about to give up and pay a pro to work on them but I will try your suggestions first. I used a lot of Brasso in the Army. Who would of thought I would be using those skills now on Motorcycle carbs.
Last edit: 20 Mar 2009 06:51 by burkmanofgod.
- Link14
- Thank you received: 6
20 Mar 2009 10:57 #273702
by Link14
Replied by Link14 on topic 81 KZ750 Carbs
I like Jr's freezer idea. I've also used just a very light smear of liquid gasket to hold those o-rings in place while I re-install them.
- burkmanofgod
- 1981 KZ750H2
20 Mar 2009 21:03 #273816
by burkmanofgod
Thanks for the Brasso tip this stuff is working great. I am recleaning everything now and with the brasso I am making it all shine like a pile of new penny's. I can't wait to get the carbs done and back on the bike. Thanks for all of your help everyone.
