Gas shutoff valve leaking
- ghunt81
17 Mar 2009 13:10 #272786
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
Gas shutoff valve leaking was created by ghunt81
Guys, I need a little assistance.
Last year I took the "pot" off the bottom of my gas shutoff valve to clean it out and make sure it wasn't full of gunk. When I did this I found out the O-ring in there was destroyed.
I tried to make a rubber washer work, but it still leaks when the valve is switched on.
What size O-ring can I use to seal this thing up? I'm looking to sell my bike, and a fuel leak doesn't look very good for that.
- timebomb33
- Thank you received: 10
17 Mar 2009 21:29 #272949
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Gas shutoff valve leaking
you can get rebuild kits the o rings are odd sized and you would have to get real lucky to find one that fit go down to your local bike shop and tell them that you need a petcock rebuild kit and they shouldn't have aproblem at all finding one to fit.
- ghunt81
18 Mar 2009 12:59 #273125
by ghunt81
Replied by ghunt81 on topic Gas shutoff valve leaking
Aha, I found a petcock O-ring kit on ebay. Sweet.
