750 carbs to my 650
- dastardize
15 Mar 2009 15:43 #272187
by dastardize
1979 kz650 hardtail
4 into 1
pods
750 carbs to my 650 was created by dastardize
i was wondering if i could use the stock kz750 carbs from an 80 and put them on my 79 kz650. the 750 carbs are jetted with 62's and 137.5's. the 650 will have pods and a kerker. will this be too much flow for the engine or should it be alright? I already got it to fire but i noticed some gas came out of the left most exhaust port but i'm not sure if it's because of the carbs or because i gave it too much gas. thanks for the help
1979 kz650 hardtail
4 into 1
pods
- timebomb33
- Thank you received: 10
15 Mar 2009 19:28 - 15 Mar 2009 19:29 #272250
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 750 carbs to my 650
sounds like it has some crud in that float valve assembly and the float is not closing proerly make sure you turn the gas off every time you shut it down or it could fill up the bottom end withgas. as far as the jetting goes i cant really help you you will most likely have to experiment a bit.
Last edit: 15 Mar 2009 19:29 by timebomb33.
- Hobo13
18 Mar 2009 14:30 #273153
by Hobo13
Replied by Hobo13 on topic 750 carbs to my 650
I'm a new member and a new owner of a 78 kz650 I don't have an answer to your ?? but I do have a question I thought maybe you could help me with. My left carb is leaking fuel from the bottom. bike still runs but it starts leaking as soon as you turn the gas on. Any ideas???I'm still very new to this bike and to web site forums!!LOL any help you can give would be appreciated
john
john
- Thank you received: 2829
18 Mar 2009 14:43 #273159
by 650ed
Replied by 650ed on topic 750 carbs to my 650
Hobo13 wrote: "My left carb is leaking fuel from the bottom."
If it's leaking from the overflow hose see timebomb's float valve advice above. If it's leaking from the drain screw you need a new o-ring. If it's leaking around the joint between the carb bowl and carb body you need a new gasket. These are all EASY to repair. Otherwise, make sure it's not leaking up higher and just running down the outside of the carb to the bottom. That could be the connector between #1 (left carb) and the #2 carb (this would not be good.) Ed
- Hobo13
18 Mar 2009 15:10 #273165
by Hobo13
thank u ed. very much. i beleive it to be float valve related as u said i will look that up try it uot and let u know thanx
