air screw
- kfe
10 Mar 2009 20:14 #271084
by kfe
air screw was created by kfe
on my 78/kz650 cant find what to set air screw at how many turns
- zoro
- Thank you received: 1
10 Mar 2009 21:29 #271098
by zoro
GHOSTRIDER,1980,KZ1000ST
Replied by zoro on topic air screw
It depends on the set up of intake and exhaust.Screw them in very carefully untill you feel it seat,or bottom out then count 1-1/2 turns left.Thats merely a starting point,and again,It depends greatly on jetting,intake breather type,and exhaust type.Youll need to set the idel and blip the throttle to find the sweet spot.It may go as much 3 full turns to the left.Turn all four screws the same number of turns,1/4 turn at a time.The factory doesnt give a definate setting because so many variables come into play such as elevation,jetting size,etc.Thats one reason they come from the factory preset and sealed.One of the 650 owners will be more helpful than me.
- wiredgeorge
11 Mar 2009 07:43 #271145
by wiredgeorge
Replied by wiredgeorge on topic air screw
I don't believe 78 VM24SS carbs have air screws... pilot fuel mixture screws. The setting depends on airbox type, pilot jet, etc. If everything is stock, try about 1 3/4 turns out from lightly seated.
- H2RICK
- Is this a fun bike, or what!!!
11 Mar 2009 13:50 #271201
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic air screw
This is eery....I was just going to post a request on this very thing.
Apparently, you folks in the US only got FUEL screw carbs on your B2As and D1As according to my FSM. (I'm not sure what the C2s for the US market used because, for some unknown reason, there is NO FSM that I can find that covers the 650C2....at least not in an English-language edition.)
However, in the rest of the world, we 650 owners got AIR-screw carbs. The initial setting for THIS type of carb (from what I can learn) is SUPPOSED to be 1 5/8th of a turn from seated.
I hope this helps.
I hope this helps.
- RonKZ650
- Thank you received: 240
11 Mar 2009 16:22 #271221
by RonKZ650
Replied by RonKZ650 on topic air screw
Some had air, some had pilot screws. I bought my 78 B2 new and it has air screw type, then my B2A has pilots. All B1s had pilots as far as I know, but at least the vast majority of B2 did have the air screws. I've had 2 C2s over the years and they both had air screws. D1 SR model had air screws. I think all the SR had air.
- rstnick
- Thank you received: 377
12 Mar 2009 06:27 - 12 Mar 2009 06:28 #271329
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic air screw
Here's a page from the factory service manual stating to start with 2 turns out from seated, and adjust from there.
This is with factory exhaust and filter.
Pic below, second page with the write up, then a dirrect link which should be clearer:
img.photobucket.com/albums/v494/rstnick/CarbMaintenance1b.jpg
img.photobucket.com/albums/v494/rstnick/CarbMaintenance2.jpg
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 12 Mar 2009 06:28 by rstnick.
- kfe
12 Mar 2009 18:21 #271441
by kfe
Replied by kfe on topic air screw
rstnick this is great thanks alot
