78kz650cant start cold
- kfe
there black
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Thank you received: 2098
Could also check float bowl fuel levels using the clear tube test. Might be too high and causing excessive richness.
Do brand new plugs make any difference?
With plugs removed, what is visually observed spark quality?
Has compression been tested, and are valve clearances to specs?
Good Luck!
- KawiConvert
- Thank you received: 4
If not already done, try cold start with choke full on and without even touching the throttle.
Good Luck!
Is starting with full chock and no throttle an indicator of carb problems?
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Thank you received: 2829
Good Luck!
- bountyhunter
- Thank you received: 337
I recall reading that pods interfere with the proper operation of the stock choke system. YMMVany way it hase pod air filters also.
- kfe
- kfe
As known, even perfect carbs can't compensate for deficiencies in compression, ignition, float bowl fuel level, ample clean fuel supply, or ample clean air supply.
Good Luck!
- KawiConvert
Enrichener circuit is designed to function with throttle slides fully closed.
Good Luck!
Glad to hear my bike is acting normal. I worried as past bikes worked with the choke and throttle. I'll stop trying to twist the throttle while starting.
- wiredgeorge
