kz900 stock carbs on a kz650?
- tgutz
10 Mar 2009 17:49 #271013
by tgutz
kz900 stock carbs on a kz650? was created by tgutz
Dyna coils and ignition, 8mm wires, coil mod,pods, 4/1 exhaust on a 78 650sr. Need to replace carbs cause of structural damage to one of the bowls,,found a set of stock kz900 carbs pretty cheap, can I use these?
- RonKZ650
- Thank you received: 240
10 Mar 2009 18:00 #271018
by RonKZ650
Replied by RonKZ650 on topic kz900 stock carbs on a kz650?
The 900 carbs are larger diameter at both the airbox and engine side so to use them you'll need pods that fit a KZ900 and intake manifold rubbers from a KZ900/1000. Bolt spacing is wider on a 900/1000 manifold so grinding the mount holes will be needed. Possible the carbs could be forced into stock KZ650 manufolds, but they would have to be brand new and pliable, old won't do. I measured once and I think there was around 4mm difference which is a lot to stretch rubber. Last problem is the 900 has dual fuel lines into the carbs where a 650 uses a single, so you'd need a T fitting to T off the line 2 ways. So possible, but not an instant bolt on swap.
- Mark Wing
- Thank you received: 22
10 Mar 2009 19:55 #271079
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic kz900 stock carbs on a kz650?
Ron's right. I'm not sure but maybe you could use the carb to air box boots from a 900/1000 to hook up the air box.
Mark
Mark
Yorba Linda Cal.
- wiredgeorge
11 Mar 2009 07:53 #271148
by wiredgeorge
Replied by wiredgeorge on topic kz900 stock carbs on a kz650?
Both Ron and Mark are correct... use VM26/28 carb holders with elongated holes. Also, test fit the 76 assembly as I recall there may be an issue with clearance of the carb holder bracket.
