- Thank you received: 1
main jets BS34 the same as VM series??
- martijn
09 Mar 2009 01:00 #270528
by martijn
main jets BS34 the same as VM series?? was created by martijn
Simple question:are themain jets of the mikuni BS34 the same as the standard kz900 VM series??
- wiredgeorge
09 Mar 2009 07:15 #270563
by wiredgeorge
Replied by wiredgeorge on topic main jets BS34 the same as VM series??
The type of jet is the same but sizes are different.
- martijn
09 Mar 2009 13:27 #270629
by martijn
Replied by martijn on topic main jets BS34 the same as VM series??
Thanks WG!
You mean a VM 100 is not the same as a BS 100?? or is the tread different
is there a calculation to use the VM's in the BS series?
Martijn
Martijn
- H2RICK
- Is this a fun bike, or what!!!
09 Mar 2009 17:23 - 10 Mar 2009 19:45 #270714
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic main jets BS34 the same as VM series??
Those round jets with the screw driver slot are Mikuni type N100/604 and they are totally interchangeable between the various Mikunis that use that style of main jet.
To expand on what George posted, they are available in sizes from as small as #50 up to as large as at least #170. They come in half sizes all the way through the range
e.g. 50 52.5 55 57.5 60 etc etc
This makes your tuning very accurate....if you know what you're doing.
PS: the N100/604 type jets are called the "reverse" style because the calibration direction is the reverse of what it is in the 4/042 style jet (Amal-style or long hex style) used in older Mikunis.
I'm just FULL of useless Mikuni trivia like that.
Last edit: 10 Mar 2009 19:45 by H2RICK.
- timebomb33
- Thank you received: 10
09 Mar 2009 19:16 #270761
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic main jets BS34 the same as VM series??
exactly the same.
- wiredgeorge
10 Mar 2009 05:21 #270870
by wiredgeorge
A VM series N100/604 in size #100 is the same as a BS series N100/604 in size #100.
