Jet size with pod filters
- lg_rebel
07 Mar 2009 23:25 #270325
by lg_rebel
Jet size with pod filters was created by lg_rebel
In December I purchased a 79' KZ1000 ST. The previous owner changed to pod filters and increased the main jet size, but I'm not sure how much. He didn't change the idle jets however because he claimed he could not get any at the time. Now the bike runs fine on the high end, but it will not idle at all. I have to continually bump the throttle to keep it running. If I crack open the choke, it will idle just fine. I think I need larger idle jets, but I'm not sure what size. The bike is stock with the original exhaust. Any suggestions as to the idle jet size I need? Thanks in advance.
- bountyhunter
- Thank you received: 337
08 Mar 2009 17:55 #270461
by bountyhunter
Replied by bountyhunter on topic Jet size with pod filters
Wired george may know the jet sizes off the top of his head, but here's a way you could look it up:
go to either bike bandit or babbittsonline.com and use their OEM search function. Look up your year and model and they will have explosion drawings showing the carbs and all avaiable jet sizes.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
09 Mar 2009 08:31 #270579
by tachrev
Build Thread
Replied by tachrev on topic Jet size with pod filters
Have you made any adjustments to the pilot screws?
What is the lowest RPM it will idle at now(if you adjust the idle screw will it idle on its own at 1500RPM...2000?)
Build Thread
- wiredgeorge
09 Mar 2009 11:52 #270617
by wiredgeorge
Replied by wiredgeorge on topic Jet size with pod filters
ST rejetting has been covered this week already in another thread.
