Slow to warm up
- SuperTrey
Slow to warm up
07 Mar 2009 17:49
Bone stock 78 kz1000
I just replaced the points/condensors and added the relay to the system that wiredgeorge suggests. Bike starts fine and runs strong, better i might add than before the relay. Timing is spot on. plugs and boots in good condition.
It seems to take a little longer to warm up to the point it will idle smoothly without babying the throttle. 3-5 miles of riding highway speed, but then idles smooth as it always has. Seems like it was warming up a little faster a few weeks ago, but it is hard to tell, since my daily drive takes me out of the driveway, onto the highway and I don't slow down again for 12 miles, and always idled fine by then.
Is this just "cold natured" and I haven't ever noticed it before because of the drive into town?
Thoughts?
Thoughts?
- gane
Re: Slow to warm up
07 Mar 2009 18:05
Trey, Mid 70's bikes were jetted lean for emissions even in the day, and even moderate temps required a minute or so before head temp came up enough for happy idle. It was easy to tell when operating temp was achieved, as idle speed would pick up @ 500 rpm. Riding before then, depending on amient temp. could take miles. moderatly dirty pilot jets would make idle mix even leaner, and emphasise poor response until good and warm. G
[img][/img] 1977 KZ1000A1
- SuperTrey
Re: Slow to warm up
07 Mar 2009 20:08
Thanks for the info! I figured this might be the case, and just taking short runs this last couple of weeks I finally noticed it.
- lewisj
Re: Slow to warm up
08 Mar 2009 17:37
Trey,
I had the same problem with my 73 z1, header and pods are the only upgrades. After talking with the guys at Z1 Enterprises at Mid-Ohio last year they suggested lowering the clip on the needle in the carbs one notch, therefore raising the needle. Bike warmed right up and idled like a dream. Just a thought is all else fails.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- bountyhunter
Re: Slow to warm up
08 Mar 2009 17:50
I have heard that going to thicker oil or synthetic oil will make it take longer to warm up. Never heard that changing the points would.
- keith1
Re: Slow to warm up
08 Mar 2009 17:52
gane wrote:
yep, nature of the beast......
