- Thank you received: 6
Acc. pumps vs. non Acc pump Carbs
- will61310
01 Mar 2009 09:04 #268923
by will61310
...1980 LTD 1000...
Acc. pumps vs. non Acc pump Carbs was created by will61310
Is there any advantage to having the carbs with the accelerator pumps? Or are the others just as good? Im talking vm 26s for a 77 ltd 1000.
...1980 LTD 1000...
- 76 LTD
- Thank you received: 1
01 Mar 2009 11:39 #268960
by 76 LTD
Replied by 76 LTD on topic Acc. pumps vs. non Acc pump Carbs
Throttle response is quicker with acc. pumps.Kawasaki started using them when they started jetting the bikes real lean to pass emmisions standards.this caused a bad hesitation so they used the pumps to correct it.
