- Thank you received: 4
Custom Throttle Cables
- KawiConvert
23 Feb 2009 15:29 #267539
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Custom Throttle Cables was created by KawiConvert
Does anyone know of a way to get the ends on for custom throttle cables? I looked at motion pro, but they want 35.00 per cable for custom. I need to make new throttle cables for my bike and for my dirtbike as well. Downfall of blending parts in from other bikes.
Thanks,
KC
Thanks,
KC
- Z1109R Fin
- Thank you received: 1
24 Feb 2009 00:22 #267677
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Custom Throttle Cables
Just got 2 throttle cables from Z1. Custom lenght, GPz550 +10cm/4". It´s $35 each but do you really have an option?
- Thank you received: 2098
24 Feb 2009 00:58 #267679
by Patton
Replied by Patton on topic Custom Throttle Cables
KawiConvert wrote:
Years ago it was common practice to make up our own cables with whatever outer and inner length desired. Different size cables in "bulk" were readily available as were various sizes and styles of cable end fittings.
Some of the end fittings attached with a set screw in the fitting that jammed into the cable running througn the fitting. But most were built in my neck of the woods by using an end fitting that had a small hole on one side just barely large enough to fit the cable through, and a larger "funnel" hole on the other side where the cable exited.
The idea was to separate and spread the cable fibers within the funnel hole, and then use solder (butane torch) to fill the hole in and around the spread cable fibers so as to prevent them from pulling back out. Grind things smooth to complete the job. The fittings were usually brass, so too much heat such as from a welding torch risked melting the fitting. I don't think the solder stuck very well to the cable strands, but did stick to the end piece inside the funnel, and served to keep the strands spread out.
Imo, the relatively inexpensive modern cables are built so much better and last so much longer that the diy versions, it's not worth goofing around with the old way where the fitting attachment was unreliable (especially in front brake cable applications, and less critical clutch cable applications).
Good Luck!
Does anyone know of a way to get the ends on for custom throttle cables? I looked at motion pro, but they want 35.00 per cable for custom. I need to make new throttle cables for my bike and for my dirtbike as well. Downfall of blending parts in from other bikes. Thanks, KC
Good Luck!
- KruZer
26 Feb 2009 14:33 #268263
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic Custom Throttle Cables
If you're looking for the brass barrel ends I have both the solder and screw on types.
I could tell you where I get them but then I'd have to "do you in".
Let me know what type you need and I'll send you a couple.
Buzz
Buzz
- MFolks
- Thank you received: 540
26 Feb 2009 20:17 #268363
by MFolks
Replied by MFolks on topic Custom Throttle Cables
www.flandersco.com/FlanCableSearch.html
is a good source for cable parts also
www.motionpro.com
and
www.barnett.com
