Silencer
- dman3998
17 Feb 2009 22:20 - 17 Feb 2009 22:21 #265810
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Silencer was created by dman3998
Any negative aspects to not installing the silencer intake section on my 1000B3? Seems like a waste of space. could put a ton of tools there instead.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Last edit: 17 Feb 2009 22:21 by dman3998.
- 6leafclover
18 Feb 2009 12:31 #265930
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Replied by 6leafclover on topic Silencer
if your talkin about on the airbox, I took mine off long ago and have never had any problems, you may need to resync the carbs I know i do, but other than that the only differance i can see is that you can hear the air going in when you rev it up but i think it sounds pretty cool
1979 KZ1000-E1/ST
Madison, IN
- Locozuna
18 Feb 2009 13:17 #265937
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Silencer
As I understand it the silencer is for just that. To remove the big sucking sound. :whistle: You gain the room but be careful putting things in there cause the airbox still needs to breath and the battery is there. Nothing that could short it should go there.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Thank you received: 2098
18 Feb 2009 14:40 - 18 Feb 2009 14:48 #265950
by Patton
Replied by Patton on topic Silencer
Okay to cut a piece of thin flexible perforated plastic as liner to prevent stuff from falling through any openings and also protect the battery.
[click image to enlarge view]
Last edit: 18 Feb 2009 14:48 by Patton.
