help seperating carbs
- warogue
15 Feb 2009 15:52 #265222
by warogue
1982 KZ750-N Spectre (Stock)
1987 EN450 454LTD
Sebastian, FL
help seperating carbs was created by warogue
Is there anything special except for elbow greese to get these seperated? All joints except the one for the butterflys are loose. I have pried them apart a little but didn't want to go to far without guidance. Thanks
1987 EN450 454LTD
Sebastian, FL
- gane
- Thank you received: 1
15 Feb 2009 16:19 #265226
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic help seperating carbs
Warouge, Sorry, no help. Am quessing your' cv's are a twin set-up. a look at manual/parts breakdown would show if butterfly shaft is dovetailed or solid. In my experiance, butterflys are installed then staked, w/ some kind of adjustable linkage in mating. I can see why a complete break down is desirable, wish i had more. luck G
- warogue
15 Feb 2009 16:23 #265227
by warogue
1987 EN450 454LTD
Sebastian, FL
Replied by warogue on topic help seperating carbs
The complete breakdown was no help with it either. I have heard others say it is a pain to get them apart and back together and all work correctly. I'm trying not to break anything. If it wasn't for the dust cover over the joint I would soak them as is.
1987 EN450 454LTD
Sebastian, FL
- gane
15 Feb 2009 16:32 - 15 Feb 2009 16:34 #265229
by gane
W. ? the breakdown didn't list shaft as 1 or 2 pieces? G./ Also, is it a choke butterfly or throttle?
Last edit: 15 Feb 2009 16:34 by gane.
- warogue
16 Feb 2009 06:42 #265338
by warogue
1987 EN450 454LTD
Sebastian, FL
I was looking at wrong diagram... I found the right one and it shows to remove the butterflys and the shaft will pull out... I feel like an Idot... Hey, I'm new at this.
Thanks for the Help. As soon as the carbs are cleaned and put back together I should be able to take it for my first ride on it.
1987 EN450 454LTD
Sebastian, FL
- PLUMMEN
- Thank you received: 104
16 Feb 2009 07:15 #265347
by PLUMMEN
Replied by PLUMMEN on topic help seperating carbs
take all the screws out and trip as youre carrying them across the floor making sure they land on bench,ive found this technique works very well for things i just spent too much time trying to put together,hope this helps !:laugh:
- gane
17 Feb 2009 19:11 #265775
by gane
W, respectfully, dis-agree w Plummen.Butterflys are usually a precise fit in bore and once disturbed a pain to re-align. thus my querie as to whther choke or throttle. If seperating carbs is manditory, ie leaking fuel tubes. I rec. removing the plate furthest from linkage arm and not disturbing other. If possible cleaning w/out removing plates, seperating carbs, is 1st opt. Luck G
