Carburetor spacing
- otakar
14 Feb 2009 07:52 #264981
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Carburetor spacing was created by otakar
I know that the carburetor spacing on the KZ1000,900,750/4, and 650 is the same. Anyone here know if the 550 also has the same spacing or is it narrower.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
14 Feb 2009 08:52 #264991
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Carburetor spacing
Ive got my rack out at the moment if you want anything measuring.[tk22's]
1980 KZ500 B2
- otakar
14 Feb 2009 09:01 #264992
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Replied by otakar on topic Carburetor spacing
Yes, Please I would love to know the Center to center spacing on the carbs.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- SPARKY47
- 1980 KZ500 B2
14 Feb 2009 09:17 #264997
by SPARKY47
1980 KZ500 B2
Hi Otakar,this is what I measure from centre to centre.
1 to 2 = 70mm
2 to 3 = 91mm
3 to 4 = 70mm
1 to 2 = 70mm
2 to 3 = 91mm
3 to 4 = 70mm
1980 KZ500 B2
- otakar
14 Feb 2009 16:02 - 14 Feb 2009 16:06 #265062
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Those are quite a bit narrower than the 650/750/900/1000/1100 units. All books have them listed as 77-93-77, which is somewhere between Kawasaki and Suzuki, but in actuality Kawasaki are 75-96-75. Most people just JAM the Suzuki carb assemblies onto the Kaws, deforming the boots. I think that this is why many times you see people advertise carb assemblies as fitting botht the GS and KZ bikes.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Feb 2009 16:06 by otakar.
- wiredgeorge
16 Feb 2009 06:38 #265335
by wiredgeorge
Replied by wiredgeorge on topic Carburetor spacing
Carb spacing is IDENTICAL for the VM26 assembly used on the GS750/850/1000 and KZ900/1000 - 77-93-77mm. It is also identical for the GS1000/1100 BS34 and KZ/GPz BS34. The GS750/850 carb holders are angled and thus the spacing of the BS32 carbs used on those models is different and while you can force them into KZ carb holders, the KZ carb holders will break fairly soon from the stress. The 550 has completely different spacing and is narrower than the 650/900/1000 spacing.
- otakar
16 Feb 2009 10:39 - 16 Feb 2009 10:45 #265396
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I measured every one of my 7 sets of extra Kawasaki carbs and they all measure 75-96-75. The GS1150 carbs I bought measure 78-94-78 both sets. I know that the dimensions in the Sudco Catalog say 77-93-77. This is the dimension which is on the Mikuni Smoothies that I have. If I try to force the GS carbs on my KZ I start dammaging my boots. There is visably a large spacing difference. Even if you try to line up the brackets from the GS1150 and the KZ1100 it is obvious.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Feb 2009 10:45 by otakar.
