How to remove and put in a new petcock?
  • 1975KZ400D
  • 1975KZ400D's Avatar Topic Author
13 Feb 2009 06:53
#264624
So, I'm kind of a newby, but this seems like something I should be able to handle on my own as opposed to taking in to the shop and paying $85 an hour for labor. I've got a leaky petcock. I just bought a new one off ebay that was originally made for the 69-74 Honda CB750 (I was told that these were compatible with my 75 KZ400). I've been searching around online, but I can't find anything that tells me step by step how to remove the old petcock and put in the new one. Does anyone know of a place that could give me step by step directions, or could any of you guys help me out with this?
Thanks a ton!! :woohoo:
  • tw..
  • tw..'s Avatar
Re: How to remove and put in a new petcock?
13 Feb 2009 08:08
#264644
Best thing to do is buy a service manual it will explain in detail how to repair everything on your bike.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
13 Feb 2009 08:18
#264647
The process is fairly simple and you can do it yourself. You may smell like gas at the end, but then you can make those clothes your garage clothes.
First unhook the hoses from the petcock (you may want to use tape to identify what hose is which if you have a vaccume operated petcock), lift up you seat, then pull up on the back end of the gas tank.This will detach the gas tank from the frame. Do not drop it. Have a place ready to set it down.
Drain the gas out of the tank.
Then remove the 2 bolts securing the petcock to the gas tank. There will be a mesh screen that comes out that prevets dirt and derbis from getting into the carbs.
Then install the new petcock using the same method as stated above in the reverse order.
I hope this infor helps.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • grumpy56
  • grumpy56's Avatar
13 Feb 2009 18:55
#264885
I am not familiar with the KZ400, but I would add to remove the tank vent hose and disconnect the fuel gauge to what is accurately stated by Kool Ryder above.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • gane
  • gane's Avatar
13 Feb 2009 20:20
#264920
400, not familiar w/your 400, but am intimate w/cb750's. from 69 thru 76 petcock was a spigot mount, petcock mount was rh thread at tank, lh at cock. with a sealing washer between. differences for application are gross. luck G
[img][/img] 1977 KZ1000A1
  • JR
  • JR's Avatar
14 Feb 2009 08:43
#264990
You can download in sections a workshop manual here
www.kz400.com/index.html
A great site which used to be run by a real gentleman who was a member here before he passed away
Like the guys above said, you will need to disconnect the hoses, drain the gastank, lift the seat, figure out how to remove the tank which may have a retaining bolt at the back or have some kind of bungee straps. There are only two or three ways the petcock will go on. Either threaded into the tank or held in with 2 screws. This should be an easy job. You can do this and save $85 an hour :)
Good luck
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
14 Feb 2009 20:34
#265113
I think you guys got it all wrong... First you have to unzip it then pull it out. Putting it back in just follow the reverse.:laugh:
79 LTD B3
  • gane
  • gane's Avatar
15 Feb 2009 15:39
#265220
I believe that model come with a collar and/or leash
  • 1975KZ400D
16 Feb 2009 18:37
#265531
Thanks for all the advice! I should be able to handle it with the info that you guys gave me. I'm just waiting on the part now.
Thanks again, this website is such a great resource!! ;)
  • Locozuna
  • Locozuna's Avatar
16 Feb 2009 19:01
#265542
:laugh: :laugh: :laugh: :laugh:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • 1975KZ400D
20 Feb 2009 11:01
#266502
Just got the new petcock yesterday and put it in today. I'm kind of embarrassed that I even asked how to do it. It took all of about 20 minutes! The Honda petcock works great! No more leaking!!!! :woohoo:
20 Feb 2009 11:04
#266504
A Honda petcock in a KZ?? Now you're going to have to buy your gas at a Honda dealership.
