Another jetting question
- lx460
11 Feb 2009 14:03 #263863
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Another jetting question was created by lx460
KZ1000P (J model) brand new rebuild, 1075 kit, valve job, new cam chain, stock cams, stock ignition, stock exhaust, airbox with KN filter, BS34 Mikuni's.
Will the jetting need to be changed now that the bore is bigger?
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- bountyhunter
- Thank you received: 337
11 Feb 2009 14:56 - 11 Feb 2009 14:58 #263871
by bountyhunter
Replied by bountyhunter on topic Another jetting question
I don't think it is required, but Wired George would be the expert on this kind of thing. I think you could get better performance going to different carburetors with a higher CFM flow, but I am not sure changing the jets in these will do what you want.
Last edit: 11 Feb 2009 14:58 by bountyhunter.
- otakar
11 Feb 2009 15:23 #263872
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Another jetting question
The 34s are enough carburetor due to the fact that everything els is the same. Your engine however will develop a bit more vacuum due to the larger displacement. This means that in fact you may go one size smaller in jets. For the time being though I don't think you will have to do anything.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- wiredgeorge
12 Feb 2009 07:04 #264114
by wiredgeorge
Replied by wiredgeorge on topic Another jetting question
This question can't be answered because you didn't say if the bike had been rejetted prior to what appears to be some engine work. If it has the stock jetting and these mods were made, it will need to be rejetted a bit. The BS34s are more than adequate for the minor work that was done.
- lx460
12 Feb 2009 13:31 #264239
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Replied by lx460 on topic Another jetting question
carbs are stock
127.5 mains
37.5 pilots
stock needles
127.5 mains
37.5 pilots
stock needles
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
12 Feb 2009 20:02 #264427
by kzz1p
Replied by kzz1p on topic Another jetting question
For whatever it's worth. Aren't these carbs. off a smog motor? They were lean from the factory due to EPA. You have a 1075 kit at risk here. What is cheaper, Richer jets to be safe side at 1st. or Buying new 1075 pistons. I would hope that it has better lungs now vs.stock. I can only afford one set of pistons myself. Treat them nice!
- wiredgeorge
13 Feb 2009 06:00 #264606
by wiredgeorge
You certainly won't hole a piston using the stock jetting. The K&N drop in filter doesn't make a great difference. Try the stock jetting and see how it runs. If it starts a bit hard, then perhaps a larger pilot jet (#40 BS30/96 type) might be needed. Try and pull redline. If it pulls redline cleanly, your jetting should be OK as is; otherwise you might need a slightly larger main jet (perhaps a #132.5)
