- Thank you received: 2829
Finally figured out why my kz 400 bobber run's bad
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
Pretty amazing what a small vacuum leak and a clogged jet can cause in performance & troubleshooting frustrations....
Now that I'm thinking about it, your posting (fixes & results) would help at least 10 of the carb postings recently put on the forum...
You reviewed & analyzed the situation and symptoms, tore into the carbs and cleaned them up, asked intelligent questions, listened to the advice provided and did accomplish the recommendations and low & behold, "hauls ass".....
Have to love it!
Way to go young man,
OMR
Thank's OMR, it feels good to actually ride this thing and not worrying about everybody else passing me because its only hitting on 1 cylinder.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
The carb holders are often the problem but just as often they are not suspected because the part you can see looks fine. I had this problem several years ago with mine, and even though the rubber I could see looked (and was) perfect the rubber mating surface that seals against the cylinder head had tiny little cracks that couldn't be seen until removed from the engine. A guy showed me the carb cleaner trick (engine died immediately) which demonstrated that those itty bitty cracks were leaking bigtime. Holders replaced - problem gone!
Ya, mine looked fine on the outside also, but when i sprayed carb cleander on them and it diewd i knew that was a major part of my problem.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
