- Thank you received: 5
810 runnin $hitty
- jordan
09 Feb 2009 15:07 #263339
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
810 runnin $hitty was created by jordan
Got to about 30 degrees last weekend so i got the 810(81 750 4cyl base)out to see if i could take it for a ride. ran crappy so i pulled off the bowls and sprayed a little carb cleaner down the in the jets to clear them out. Still ran crappy but i jumped on it and went for a ride. Seemed to run fine wide open but when you let off the throttle at any rpm it takes a long tim to idle back down. Doesnt matter if there is load on the motor or not. after you let off the throttle it slowly drops rpm until idle. Does this sound like a vacuum problem? Last year i got rid of the vacuum system and capped off the vacuum nipple deals. Maybe they are wearing/cracking and leaking? It hasnt been ran much since the rebuild so i wasnt sure that it wasnt motor problems. Put a set of carbs off my buddys 750 on and it ran great and was a blast to ride.
Anybody got any ideas of the problem by the symptoms?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- wiredgeorge
09 Feb 2009 15:52 #263344
by wiredgeorge
Replied by wiredgeorge on topic 810 runnin $hitty
No idea what carburetors you are using. That might help narrow a diagnosis. If you capped the vacuum fittings on constant velocity carbs, what did you use?
- jordan
09 Feb 2009 17:39 #263374
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic 810 runnin $hitty
i believe the carbs are called a bs34. They came stock on the 1982 kz750 4cyl bike that i own. I capped off the vacuum ports with vacuum plugs from autozone. I have heard that these caps are junk and dont last very long. They always ran good on whatever bike i had them on for about a year until now.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jordan
10 Feb 2009 11:45 #263554
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
bump
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- wiredgeorge
10 Feb 2009 11:57 #263557
by wiredgeorge
Either buy some of the big fat plugs that Z1enterprises.com that would normally go on the vacuum ports of carb fittings for VM carbs or use VINYL caps. The rubber caps don't last very long. I used them initially in my business and noticed that they tended to crack in a few months and allowed the idle to race. It sounds as if you may have cracks in those caps. Check and get back.
- jordan
15 Mar 2009 20:36 #272260
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
k, finally got nice out and i have had the bike out quite a bit. Hauled it up to college. Put new vacuum caps on and it still has the same problems. After it warms up the, the throttle seems to stay open and slowly idle back down. Also is very hard to get it to idle. Also, i have been fighting with the float level alot lately. Adjusted it many times with no luck. When the bike idles for a while, or when the gas is on and the bike is off, it floods. Also have noticed that even when riding at a lower rpm, it bogs when i try to accelerate. Runs great wide open or at higher rpm's. Is this just a float problem that i must not be fixing right or could it be something else?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
- Thank you received: 10
15 Mar 2009 20:43 - 15 Mar 2009 20:45 #272262
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 810 runnin $hitty
hey jordan pull off the carbs and take some spray carb cleaner and pull your pilots out and spray thru them and also the passages and then blow them out with compressed air and that shoud cure the problem also remember to take your slides out because the carb cleaner will swell the diaphrams give me a call if you have any problems 1-780-835-6687.good luck let me know how it goes and by the way you suck it is snowing again up here and i probably won't be able to ride until april some time if then even. pilots are plugging up that is your problem typical spring problem
Last edit: 15 Mar 2009 20:45 by timebomb33.
- jordan
16 Mar 2009 09:10 #272368
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
thanks alot man, will definately give it a try here today or 2morrow.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
