is this supposed to be removed? 82 kz750 spectre
- warogue
09 Feb 2009 08:02 #263258
by warogue
1982 KZ750-N Spectre (Stock)
1987 EN450 454LTD
Sebastian, FL
is this supposed to be removed? 82 kz750 spectre was created by warogue
I am tearing down the carbs and have this plastic plug that twists but doesn't seem to want to come out. I'm figuring this needs to come out before soaking the carbs. 82 kz750 spectre
Thanks
Thanks
1987 EN450 454LTD
Sebastian, FL
- loudhvx
- Thank you received: 1616
09 Feb 2009 08:44 #263262
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic is this supposed to be removed? 82 kz750 spectre
I think there may be another jet under that plug.
1981 KZ550 D1 gpz.
Other links.
- JMKZHI
- Thank you received: 48
09 Feb 2009 10:01 #263273
by JMKZHI
Replied by JMKZHI on topic is this supposed to be removed? 82 kz750 spectre
Don't quote me on this, but I'd guess that the cap is supposed to be pulled out. It may have an o-ring on it that's most likely hardened. Maybe shoot some silicone spray or sumthin' on it.
Kawasaki.com has parts diagrams in the Owner Info section.
- bill_wilcox100
- Thank you received: 5
09 Feb 2009 11:19 - 09 Feb 2009 11:36 #263284
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic is this supposed to be removed? 82 kz750 spectre
warogue, as mentioned check the Kawasaki site for all the diagrams and part descriptions for your bike here:
'82 KZ750-N1 Spectre
As you can see, the cap, O-ring and hidden jet are described as follows:
Ref No
Part No
Description
11012
11012-1128
CAP, POLYESTER
92055B
92055-1088
"O" RING
92064
92064-1001
PILOT JET, #35
Based on this, looks as if all you have to do is pull the Polyester Cap a little harder to over come the O-ring and expose the Pilot jet then you'll be good-to-go.
Best of success.
PS
Could you add your year, model and location to your signature to get the best responses... and it's considered real friendly too. And I find it cool to know were y'all come from.
Bill
Ref No
Part No
Description
11012
11012-1128
CAP, POLYESTER
92055B
92055-1088
"O" RING
92064
92064-1001
PILOT JET, #35
Best of success.
PS
Bill
Upgrades:
Montreal, Canada
Last edit: 09 Feb 2009 11:36 by bill_wilcox100.
- warogue
09 Feb 2009 11:52 #263292
by warogue
1987 EN450 454LTD
Sebastian, FL
Replied by warogue on topic is this supposed to be removed? 82 kz750 spectre
Thanks for the Info... I have sprayed it and waiting a bit for it to seep through. I'll let you know how it goes.
Drew
Drew
1987 EN450 454LTD
Sebastian, FL
- warogue
09 Feb 2009 14:32 #263335
by warogue
1987 EN450 454LTD
Sebastian, FL
Caps are out... now time to get the jet un-gunked
1987 EN450 454LTD
Sebastian, FL
- wiredgeorge
09 Feb 2009 15:54 #263345
by wiredgeorge
Replied by wiredgeorge on topic is this supposed to be removed? 82 kz750 spectre
That is a plug w/ o-ring to plug the slow jet well. The #35 slow jet is beneath that plug. It draws gas from a cross passage from the main jet well. The plug needs to come out and the pilot jet needs to be removed and cleaned. It can't be replaced as replacments are no longer available.
