jetting
- trougher
- loudhvx
- Thank you received: 1616
With a Kerker (which is pretty restrictive compared to a Mac or open canister), and Emgo pods, I'm using 99 mains with 34 pilots. I drilled the jets myself.
It's really going to depend on the amount of restriction in the exhaust and restriction in the pods, but 99 mains and 34 pilots are a good starting point and will allow the air screws to be in the normal range of turns which gives best tunability for idle and off-idle.
Also check out this mod for the choke system:
www.geocities.com/loudgpz/GPZchokeScrewMod.html
The crankcase vent can just get a tube to the ground. I use a brass elbow that I threaded into the cover (with a pipe tap). The elbow prevents the vinyl tubing from kinking. Here's a photo of the cover on the motor. Sorry I don't have a closeup.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- trougher
- bountyhunter
- Thank you received: 337
Gotta ask: if it ran awesome with header and stock airbox, why not keep that setup? The carbs are designed to work with the airbox.Looking for some help to determine what sizes I should go to .I have An 81 GPZ 550 with Tk 22 as well . Has 94 mains and 32 pilots ( stock I think ). Putting on A header an pods .Ran awesome before when it only had the header.
- bountyhunter
No offense to any posters, but every post I have ever read as well as my own MAC header indicates the opposite is true. My MAC (running now) flows maybe as good as stock did, my Kerker clone jetted up richer and made HP like a bandit.Thanks for the info. So mac flows better .
- loudhvx
With stock airbox/filter and Kerker I could basically run stock jetting albeit taking a little longer to come off the choke on colder days. Ideally, with stock airbox/filter and Kerker, the bike liked 96 mains and could get by with stock pilots. With a change to the Mac, it would never run without stuttering and the EGA was pinned lean. With the Mac and Airbox I run 99 mains with 37 pilots. This was the only way to get the screws in their normal range and gave the smoothest overall running. You can get by with just 102 mains and stock pilots, but the screws will be in the 1/2 turn range and the bike will take longer to come off choke (stuttering all the while).
Now, I'm not saying the Mac flows "better", it's just less restrictive and/or requires larger jetting. I believe overall, a proper Kerker gives better low end torque which makes launches much easier and more fun especially if you have a passenger. I've been running Macs and Kerkers exclusively (on several 81 GPZ550's) for over 15 years (documenting many carb/exhaust/jetting combinations all the while) and these are just my findings/impressions.
However, I never did run a Mac with pods. I know I wouldn't have liked that combo. Both conspire to kill low-end torque. I find I like the kerker with airbox combo best, and kerker with emgo disposable pods as long it's a solo bike only.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
I can drill them for you if you feel like sending them to me in a padded envelope etc.
1981 KZ550 D1 gpz.
Other links.
