OK I'm nearly happy !!
- triggerbilly
02 Feb 2009 16:35 - 02 Feb 2009 16:37 #261772
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
OK I'm nearly happy !! was created by triggerbilly
Right .....
I put the pingel adaptor on my tank and got rid of the shite leaky vacume petcock and put a 3/8 manual sportster type petcock on.
I also ripped out the smog system and capped off all the nips on my carbs and ...... It's running alot better
still a huge backfire as i turned off the ignition and alot of spiting kinda noises coming from the pods (don't know if thats usual or not)
AND ALL CYLINDERS ARE FIRING NOW !!!!
I'm guessing that maybe the leaking petcock was flooding 2 of the cylinders out ??
any thoughts on the backfire
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 02 Feb 2009 16:37 by triggerbilly.
- Thank you received: 2098
02 Feb 2009 19:38 #261824
by Patton
Replied by Patton on topic OK I'm nearly happy !!
triggerbilly wrote:
guessing that maybe the leaking petcock was flooding 2 of the cylinders out --- imo "NO"
Suggest complete tune-up per FSM , with carbs addressed last.
During ign timing stage, assure auto adv is functioning, and clean/lube it if nec.
Good Luck!
Right .....
Good Luck!
