air screws or pilot screws or what????
  • indykaw77
  • indykaw77's Avatar Topic Author
24 Feb 2006 12:03
#26132
OK....1977 kz1000A. How do I go about identifying my carbs? Is there a "carb #" or tag or something somewhere? Can't tell from the Clymer....they all seem to look alike. And it mentions "with air screws" and "with pilot screws". Just wanna know for future referance, is all. Thanks in advance...
Kawasaki Motorcycles...because cars lean th wrong way!
  • DanOz7Five0
  • DanOz7Five0's Avatar
Re: air screws or pilot screws or what????
26 Feb 2006 10:03
#26539
There is sometimes a number stamped into the flange where the carbs mount to the engine.
For air or pilot screws look at the sides of you carbs. There may be a screw (or an aluminum cap over a screw) on the outside of the carb, those would be air screws. If its not there look by your float bowls, for a hole or tube with a screw at the bottom of it, those would be fuel screws.
Heres a pic of air screws, but for a Mikuni VM24, maybe its of some help.
  • indykaw77
27 Feb 2006 03:07
#26725
Thanks.....a KZ guru here helped me do some stuff this weekend and tells me I got the stock 26's on this thing, and verified that I got the air screws.
Thanks for the info, tho........
  • Alex_KZ1K
  • Alex_KZ1K's Avatar
27 Feb 2006 05:19
#26730
Well then, I just confirmed I have the air screws on my stock VM28's. For some reason I thought I had fuel screws before I took a good look at them. Thanks for the info!
  • GargantuChet
  • GargantuChet's Avatar
27 Feb 2006 06:32
#26740
Fuel screws are under the carbs, towards the front of the bike. Or so it is with the SR.
  • xr350guy
  • xr350guy's Avatar
27 Feb 2006 20:09
#26942
sorry to be off topic, but this has been bugging me.....gargantu, is that actually a picture of you as your avatar???
