Mikuni BS36SS For my GPz1150
- mark1122
- Keep twisting it
Re: Mikuni BS36SS For my GPz1150
01 Feb 2009 13:11
Why not just use a set of RS34's. Better signal for bottom end responce, and only 4 to $500 used .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- otakar
01 Feb 2009 16:27
The reason I do not want to use RS34s is two fold. One is that I have not seen any go as cheap as 500, 2) because I want to stay with CVs RSs use quite a bit more gas on the street, and only give you an "Off-the-line" advantage. Quite often you will actually loose top end with them by a few MPH.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
02 Feb 2009 05:26 - 02 Feb 2009 05:28
I guess i just got lucky. I paid $450 for mine. New 1's are $680 at Sudco.
Anyways you've done a lot of work with those . I hope u are able to make them work.It will be very gratifiing for u , for sure.Good luck.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 Feb 2009 05:28 by mark1122.
- otakar
02 Feb 2009 05:44
Unfortunetly the hard work has not even started on these carbs. i will keep you all posted.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- porchev914
25 Apr 2010 14:20
Bump...Did you ever make those BS36's work? I ask because I have a pristine set off of a Suzuki RF900. It looks like the #2 and #3 carbs are centered well, and the #1 and #4 carbs are 3mm or so too wide on each side. So, I'm curious if you were able to solve the spacing issue. Sorry to drag up such an OLD post :laugh:
FRANKEN Z!
- otakar
03 May 2010 17:29
I gave up for the time being because the cutting and rewelding of the control arms is a pain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
