Another petcock question...
- 6leafclover
30 Jan 2009 21:07 #261025
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Another petcock question... was created by 6leafclover
I just ordered a new petcock (the 12 dollor one) from Z1 I also got the adapter plate but i got the offset one because i was afraid that the side outlet on the new petcock would hit the air box so move it forward right? well do ya think I'll have to cut out the hole in the tank at all for it being so far to the front, its a 79 1000 shaft by the way?
1979 KZ1000-E1/ST
Madison, IN
- wiredgeorge
31 Jan 2009 07:11 #261107
by wiredgeorge
Replied by wiredgeorge on topic Another petcock question...
I have one of the adapter plates on my 79 shafty and you do need to open up the hole in the tank in order to get the somewhat larger diameter innards of the new petcock in. I use a Dremel with grinding stone then finish off with a sanding drum.
- 6leafclover
31 Jan 2009 07:36 #261114
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Replied by 6leafclover on topic Another petcock question...
I kinda thought that I would, so its okay that I got the offset one though? I shouldent have any problems with that right long as i can open up the hole to make it fit
1979 KZ1000-E1/ST
Madison, IN
- Thank you received: 2098
31 Jan 2009 08:10 #261122
by Patton
Replied by Patton on topic Another petcock question...
6leafclover wrote:
Seems logical, but would be extra-cautious with regard to application, fitment and clearances involved, because the Z1E listing for the off-set adapter shows it being for two Suzuki models, not KZ.
Good Luck!
Good Luck!
- 6leafclover
31 Jan 2009 09:27 #261133
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Yea I noticed that too but i figured if the bolt patterns are the same id have to cut out the hole a little anyway so i should be able to make it work
1979 KZ1000-E1/ST
Madison, IN
- mumbles
- Let's do it...
31 Jan 2009 14:34 #261175
by mumbles
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
Replied by mumbles on topic Another petcock question...
Also don't forget to add an inline fuel filter if ya don't already have one. Don't need to take a chance of some metal shavings to go into the carb. :ohmy:
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
- 6leafclover
31 Jan 2009 15:08 #261177
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
thought of that too and I think its another benifit of having forward more, it will use more line and give a little more room for a filter
1979 KZ1000-E1/ST
Madison, IN
