- Thank you received: 6
1982 KZ1000 Petcock Question
- grumpy56
30 Jan 2009 18:06 - 30 Jan 2009 18:08 #260991
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000 Petcock Question was created by grumpy56
My 1982 KZ1000 fuel petcock began leaking like a sieve during a ride the other day. It was OK when in the "On" or "Reserve" position without the engine running, but start the motor or put in on "Prime" and it was a gully washer. The leak appeared to be coming from the seals around the diaphram or the plastic spacer. Anyway, yesterday I took the tank off and began draining the tank (on "Prime") to rebuild the tap. Not a drop from the area that was leaking when everything was connected. Would that be normal due to pressure within the system (when connected) or do I have some other (carb) problem? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Last edit: 30 Jan 2009 18:08 by grumpy56. Reason: delete emoticon
- Bluemeanie
- Thank you received: 14
31 Jan 2009 06:07 - 31 Jan 2009 06:08 #261091
by Bluemeanie
Replied by Bluemeanie on topic 1982 KZ1000 Petcock Question
On a vacuum petcock the diaphram seals itself (and fuel flow) when there is no vacuum (engine off) When the engine is started and petcock in "on" or "reserve" posistion, vacuum pulls on the diaphram and allows fuel to flow. There is a hole in your diaphram which is allowing fuel to leak out of the weep hole in the plastic spacer. If you were to look closely at the petcock while it's running you would have seen a fine mist of fuel pumping out from diaphram with each vacuum pulse. A new diaphram should take care of your problem. Be careful handeling the thin diaphram when installing... Let us know
Last edit: 31 Jan 2009 06:08 by Bluemeanie.
- grumpy56
31 Jan 2009 06:22 #261092
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Replied by grumpy56 on topic 1982 KZ1000 Petcock Question
Thank you BlueMeanie!
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- timebomb33
- Thank you received: 10
31 Jan 2009 20:05 #261258
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1982 KZ1000 Petcock Question
buy a pingel and save your self a world of suffering
