i.d. carbs and float bowls-pic added
- jpswino
28 Jan 2009 07:23 - 28 Jan 2009 07:36 #260626
by jpswino
i.d. carbs and float bowls-pic added was created by jpswino
I have what I think are 29mm Mikuni Smoothbores. I got them on a Honda motor from a friend. I'd like to use them on the 1000 build I am starting. Can anyone i.d. these? And where would I find float bowls for them? Are there aftermarket ones available? Resto-work or original stock is not important to me.
I have a pic of them on the Honda motor when I first got them. I'll try to load it and edit the post.
Last edit: 28 Jan 2009 07:36 by jpswino.
- jpswino
28 Jan 2009 09:19 #260644
by jpswino
Replied by jpswino on topic i.d. carbs and float bowls-pic added
Will these fit my carbs?
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...ME:X:RTQ:MOTORS:1123
I may have just made a mistake and allow someone else to bid against me. Oh well. Gotta trust someone, right?
- Z Krazy 1
28 Jan 2009 14:47 #260700
by Z Krazy 1
I don't care how they do it in California
Replied by Z Krazy 1 on topic i.d. carbs and float bowls-pic added
Honda has a different carb center.You must have Z or Suk.,to work on a Z
- jpswino
28 Jan 2009 16:37 - 28 Jan 2009 16:38 #260720
by jpswino
That set up has a modified boot set designed to adapt kawi carbs to honda spacing, not stock honda, so when I go to put it on the kawi it should bolt right up.
Last edit: 28 Jan 2009 16:38 by jpswino.
- jpswino
28 Jan 2009 16:41 #260723
by jpswino
- jpswino
28 Jan 2009 16:47 #260728
by jpswino
